AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
710479270 error
3 REPLIES 3
krmajczak
166 Views, 3 Replies
710479270 error
Hi!
I'm using AutoCAD LT 2016. For a week I've got a problem with 710479270 error, which causes the program to close. I'm tring to open the file and then it suddenly closes. After 8-10 tries it works. It's a little anoying. Do you know this problem?
3 REPLIES 3
hwalker
in reply to: krmajczak
Unfortunately we're only users like yourself.
I would try a repair reinstall and if that doesn't work contact support
Contact Customer Support | Autodesk Support
Howard Walker
Left Handed and Proud
pendean
LT2016 is not new @krmajczak
Did you just get a new PC or opt to install WIndows11 by chance?
What triggers the error exactly? I assume you ca get it to do so all the time with all files or by just by starting Lt2016 alone?
krmajczak
in reply to: pendean
I'm not sure what triggers the error. I reported few times the 710479270 error to the Autodesk and now it's working. So I think the problem is solved. Thank you all for answering 🙂
Forma Design Contest
Technology Administrators
