Hi!
I'm using AutoCAD LT 2016. For a week I've got a problem with 710479270 error, which causes the program to close. I'm tring to open the file and then it suddenly closes. After 8-10 tries it works. It's a little anoying. Do you know this problem?
Solved by krmajczak. Go to Solution.
Unfortunately we're only users like yourself.
I would try a repair reinstall and if that doesn't work contact support
Contact Customer Support | Autodesk Support
Howard Walker
I'm not sure what triggers the error. I reported few times the 710479270 error to the Autodesk and now it's working. So I think the problem is solved. Thank you all for answering 🙂
