AutoCAD Forum
yellow or blue lines in pdf
3 REPLIES 3
1298 Views, 3 Replies
Hello everyone
Since a few months, when I try to plot with the dwg to pdf.pc3 plotter, I get blue or yellow lines interferring my drawing. It is also hard for my adobe acrobat to open these drawings, it shuts down after a while. When I plot with another pdf plotter than I don't have the problem but my files get way bigger then. Opening the files on another pc doesn't give the problem, however it is still hard to open it in any pdf writer.
Following pictures illustrate the problem.
3 REPLIES 3
imadHabash
if you try from  _plottermanager command to delete your dwg to pdf.pc3 plotter , then copy the same from another same version , any changes ? if NOT ... i suggest to :
  • check if there is any updates needed . >> Click <<
  • Reset AutoCAD to defaults . >> Click <<
Imad Habash
in reply to: imadHabash
Hi imadHabash
I followed your advice (created a complete new plotter via the wizard though) and it worked! Thanks a lot. Yet, my file size seems quite big still.
imadHabash
>> .... and it worked! Thanks a lot.
Great ... you're welcome !!
since we don't know what you're plotting from AutoCAD then i can not give a hint !! but if you can attache your CAD drawing here for testing maybe we can help ?
Imad Habash
Forma Design Contest
AutoCAD Beta
