AutoCAD Forum
XRefs from Autodesk Docs not publishing
1 REPLY 1
jon_crowson
174 Views, 1 Reply
Recently updated to AutoCAD 2025 and using Autodesk Docs. When a sheet set from Docs is published through Sheet Set Manager for Web, XRefs are not publishing. When plotting a single page, XRefs appear without issue. When selecting multiple tabs from a drawing (or multiple drawings), and using publish (not through Sheet Set Manger for Web) all XRefs print as expected. Why do XRefs not publish when publishing from Sheet Set Manager for Web?
@jon_crowson - the moderation team has edited the title for clarity.
1 REPLY 1
pendean
in reply to: jon_crowson
Is there an error message? There usually is with missing XREFs when publishing.
Where are you launching PUBLISH from?
What are your PUBLISH settings when compared to your PLOT settings?
Forma Design Contest
AutoCAD Beta
