AutoCAD Forum
X-ref Annotation Scale Inconsistency
5 REPLIES 5
Jake_PCH
168 Views, 5 Replies
I have encountered an error with annotation scales when an X-ref (File A) is loaded into the sheet file (File B). As you can see from the screen grab, additional 'x-ref scales' were imported, even though the corresponding scales match between files; ie. 1:50 = 50 drawing units in each file.
Can anyone identify the issue?
Files attached.
5 REPLIES 5
RSomppi
in reply to: Jake_PCH
It's normal behavior, similar to layers getting a prefix even if they match layers in the referencing drawing.
Jake_PCH
in reply to: RSomppi
Thank you for bringing that to my attention.
I presumed this was the cause of the issue with the annotative labels and dimensions (shown below). If this is not the case, any insight would be appreciated.
Sheet File:
X-ref File
user181
In your sheet file you have the ANNOALLVISIBLE on. This will always show annotative text and objects at every scale. Set it to 0 to only see annotative at the current scale. You can also click the button shown below to turn on and off.
pendean
@Jake_PCH wrote:
That content in your top file resides in your XREF file if you turn on and thaw all the layers
You forgot to freeze viewport-specific layer(s), that's all.
Jake_PCH
@user181 That is an silly oversight on my behalf - thank you very much for pointing it out!
@pendean Thank you for taking the time to respond but the fix was simply turning off 'ANNOALLVISIBLE'.
Technology Administrators
