I have encountered an error with annotation scales when an X-ref (File A) is loaded into the sheet file (File B). As you can see from the screen grab, additional 'x-ref scales' were imported, even though the corresponding scales match between files; ie. 1:50 = 50 drawing units in each file.
Can anyone identify the issue?
Files attached.
Solved by user181. Go to Solution.
Thank you for bringing that to my attention.
I presumed this was the cause of the issue with the annotative labels and dimensions (shown below). If this is not the case, any insight would be appreciated.
Sheet File:
X-ref File
In your sheet file you have the ANNOALLVISIBLE on. This will always show annotative text and objects at every scale. Set it to 0 to only see annotative at the current scale. You can also click the button shown below to turn on and off.
