AutoCAD Forum
wipeout
8 REPLIES 8
Message 1 of 9
426 Views, 8 Replies
wipeout
Hello .. when I insert a block with a wipeout (for example, a block of a door that breaks the wall) everything is fine ..
but when I put this initial drawing as x-ref or with x-ref in x-ref (2 times) it does not work (the wall is not breaks)
what to do in this case?        Autocad2012
8 REPLIES 8
Message 2 of 9
RobDraw
There are a number of issues with wipeouts. I avoid using them.
Rob
Message 3 of 9
mehrdad.rahimi.en65
hello my friend
are you check the draw order? in first set draw order of your object in (bring above objects)
MeHrDaD RaHiMi
Revit Architecture Certified Professional
Revit Structure Certified Professional
Message 4 of 9
in reply to: mehrdad.rahimi.en65
Yes I did it..
Message 5 of 9
pendean
Move away from Wipeouts, they are troublesome in Xrefs in your old version of AutoCAD.
Message 6 of 9
murray-clack
in reply to: pendean
I've never had problems with wipeouts and use them all the time.
However, I WILL say that I've had coworkers have a similar problem (albeit, very rare), and there were two tricks:
1. Make sure your CAD has the latest software patches and updates
2. Recreate the wipeout within the block.  It may be corrupt
Message 7 of 9
RobDraw
in reply to: murray-clack
You're lucky. Many have and there are many posts about them. For example, when plotting to PDF they show as solid black rectangles. There are also problems with them holding the draw order. Not so much in blocks but when used as stand alone entities.
Rob
Message 8 of 9
in reply to: RobDraw
Found the root of cause !!!
The  wipeout was in the defpoint layer, changed it to 0
right now it works ..
Message 9 of 9
imadHabash
Advice ... try to NOT use Defpoints and 0 layers , i suggest always to make your own layers .
Imad Habash
Forma Design Contest
AutoCAD Beta
