I'm having this problem with a dim style (it uses architectural tic) where there is a break right where the leader connects with the arrowhead, it only happens when the leader is perpendicular with the dim line. Pls Help!!!! see attached.
Solved by dbroad. Go to Solution.
.... thought i had something but im finding the same thins as @Anonymous
CADnoob
I created a new dim style and set it like my old one, works fine now, its just that its not the first time its happened and I would really wana know how to fix it permanently.
I guess it might just be corrupted somehow.
thanks a lot for letting me know that the problem occurs on your computer as well
I don't think it is a problem with your dimension style. The dimension itself appears to be broken, as if that is possible. Adding another dimension to replace it results in no problem.
