Message 1 of 18
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As the title says, whenever I try to hatch I get the following error code:
"C:\users\xxxxxxxxx\appdata\roaming\autodesk\autocad 2025\r25.0\enu\support\acad.pat"
The most recent update has really screwed my program up. From random crashed with no backup created to now this...
Things I've checked and done:
1. The support file points to the correct path.
2. The path referred to in 1 is populated with all the correct hatch information
3. I've established the support path but same issue occurs
(I removed my name from the file location and replaced with a series of X's)
