I am not that familiar with autocad - this is not a command or setup that I have used before.
With Autocad 2023 the multiple filenames automatically displayed as a type of tab above the pulldown menus at the top. I am now on Autocad 2024 and would like to set it up the same.
I do not want the opened file to be "minimised" at the bottom
Solved by pendean. Go to Solution.
Hi – you will see all the drawings that I have opened display as thumbnails at the bottom in my taskbar – as you move your cursor over the autocad icon on the taskbar – all the drawings will appear.
So you will see the current drawing that is open – the filename shows right at the top of the screen.
With 2023 the multiple files opened use to display between the top row and pulldown menus as tabs next to each other – I would like to set up that feature again if possible please
Thank you - Dalene
<![if !vml]>
<![endif]>
Thank you - Dalene
@DaleneATTQE wrote:
thank you - so simple - I feel embarresed - It works - jay!!
No worries, you did not know but now you do. Happy cadding!
