AutoCAD Forum
when opening multiple files - I want the filenames to display above the top pulldown menus
6 REPLIES 6
DaleneATTQE
999 Views, 6 Replies
I am not that familiar with autocad - this is not a command or setup that I have used before.
With Autocad 2023 the multiple filenames automatically displayed as a type of tab above the pulldown menus at the top. I am now on Autocad 2024 and would like to set it up the same.
I do not want the opened file to be "minimised" at the bottom
6 REPLIES 6
pendean
in reply to: DaleneATTQE
Show us what you see please: full program window screenshots from 2024 (and 2023 if you still have it) is a good place to start.
DaleneATTQE
Hi – you will see all the drawings that I have opened display as thumbnails at the bottom in my taskbar – as you move your cursor over the autocad icon on the taskbar – all the drawings will appear.
So you will see the current drawing that is open – the filename shows right at the top of the screen.
With 2023 the multiple files opened use to display between the top row and pulldown menus as tabs next to each other – I would like to set up that feature again if possible please
Thank you - Dalene
<![if !vml]>
<![endif]>
pendean
DaleneATTQE
Thank you - Dalene
DaleneATTQE
in reply to: pendean
thank you - so simple - I feel embarresed - It works - jay!!
pendean
No worries, you did not know but now you do. Happy cadding!
Forma Design Contest
