Help required with copying polylines from one dwg to another.
When copy (using copy to clipboard or _copy) and pasting from one file to another, only a 'C' appears.
The layers are the same on both files and it is not a large amount being copied. Can anyone help?
Dominic
1. Before past Clean up cad file click here
or
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists, Please give me a bit more detail on this issue so we can continue to work towards getting this solved. ?
Thanks You
Jayhar.M.J
@Anonymous wrote:
.… When copy (using copy to clipboard or _copy) and pasting from one file to another....
Those are very different things. _COPY is for use only within the current drawing. Read about it in Help. If you are using that somehow [and not paying attention to what the prompts are asking for], and then getting into another drawing and Pasting, you will get whatever may be in the clipboard, but it won't be what you selected in the COPY command [which has nothing to do with the clipboard].
