Removing web & mobile from Quick Access Toolbar
BudW
Message 1 of 12
BudW
It appears that the new open to and save to web & mobile icons can not be removed from the Quick Access Toolbar.  Since we don't have access to these features I see no reason to have the icons on the toolbar.  I am able to remove all the other icons but not those two.  I tried creating a new toolbar and deleting the original but all that did was eliminate all but those two icons.  Can someone check this on their machine to see if I'm doing something wrong?
I'm running AutoCAD 2019 Version P.46.0.0 on Windows 10 Pro, Version 10.0.16299
Replies (11)
Message 2 of 12
j_weber
I try the same an have the same effect.
I can't remove this Icons form the QAT.
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
Message 3 of 12
cadffm
Message 4 of 12
john.vellek
Hi @BudW,
Why do you say you don't have access to these features? Are they not functioning for you?
As @cadffm indicted from my post on another thread, the removal of the two icons is  a known issue.  I anticipate a fix for this to be released in the very near future.
John Vellek
Message 5 of 12
BudW
We are not on subscription, we are on a maintenance plan.
Message 6 of 12
john.vellek
HI @BudW,
Do you have access to the new update (2019.0.1)? Once it is installed it allows you to remove the two icons from the QAT
John Vellek
Message 7 of 12
BudW
Once I was able to get the update installed (that's a different problem) opened up 2019 and those icons are gone.
Message 8 of 12
Equipo\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R23.0\ACAD-2001:409\WebMobile
DisableWebMobile = 1
Message 9 of 12
It didn't work for me.....
So, I did this on my registry and it worked
For Autocad 2019
1. Press Windows Logo+R
2. Type (regedit) and press Enter
3. Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R23.0\ACAD-2000:409\WebMobile
4. Change the value of (DisableWebMobile) from 0 to1
5. Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R23.0\ACAD-2001:409\WebMobile
6. Change the value of (DisableWebMobile) from 0 to1
7. Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R23.0\ACAD-2004:409\WebMobile
8. Change the value of (DisableWebMobile) from 0 to1
9.Exit Registry Editor
For Autocad Architecure 2019:
3. Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD Architecture 2019 - English\WebMobile [ Note: if you can't find "WebMobile", you can create new key]
4 Change the value of (DisableWebMobile) from 0 to1 [Note: if you can't find "DisableWebMobile", you can create new DWORD 32]
5. Exit registry editor
For Autocad Civil3D 2019:
3. Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Autodesk Civil 3D 2019 - English\WebMobile [ Note: if you can't find "WebMobile", You can create new key]
Message 10 of 12
Alfred.NESWADBA
no need for registry hacks, just install the latest update for AutoCAD 2019 and that is solved.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 11 of 12
I have the latest software but the bugs are still there so I have no choice. I need to edit the registry.
Message 12 of 12
Alfred.NESWADBA
Can you please start command _ABOUT and show a screenshot from that dialog?
- alfred -
Alfred NESWADBA
