AutoCAD 2019 - cannot remove buttons from QAT
w64bit
Message 1 of 13
w64bit
On 2019/ LT 2019 how I can remove the 2 buttons "Web mobile" form QAT?
I tried all:
- right click - remove
- customize QAT
- CUI command
no result.
Replies (12)
Message 2 of 13
john.vellek
Hi @w64bit,
Yes, this is a known issue and the team is actively working to getting this corrected.  I hope that we will see a solution in the near future.
John Vellek
Message 3 of 13
pendean
Community Legend
Community Legend
You jumped too soon: thanks for identifying all the bugs for Autodesk 🙂
Message 4 of 13
john.vellek
Hi @w64bit,
I am checking back to see if my post helped you with your problem or question.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 5 of 13
w64bit
It would if you can post the solution/patch link.
Message 6 of 13
john.vellek
Hi @w64bit,
If you have access to the update released today (2019.0.1), you should now be able to remove the two icons from the QAT
John Vellek
Message 7 of 13
EMCARCH
Installed update and still not able to remove the two items.
Message 8 of 13
john.vellek
Hi @EMCARCH,
Please tell me your exact AutoCAD version by typing ABOUT at the command line.  I want to make sure that the update got applied and did not fail at some point during the installation.
With the update applied on my computer, I have no issue in starting the CUI editor and removing them.
John Vellek
Message 9 of 13
EMCARCH
It is Autocad Architecture 2019
Message 10 of 13
john.vellek
Hi @EMCARCH,
Yes, please type ABOUT and give me the exact version number that is installed.
John Vellek
Message 11 of 13
EMCARCH
8.1.60.0 autocad architecture 2019.0.1 - is that what you need?
Message 12 of 13
EMCARCH
I did not try the way you showed. I just tried with the CUI window open. I think this worked. Will reboot and find out. Thanks!
Message 13 of 13
EMCARCH
Just re-booted and it stayed! Thank you!!!!! Hard to believe that little bit will make things so much better.
