Please refer to the attached print screens...what setting turns this off in Autocad 2015? Whenever I draw anything or move, copy, etc. it shows this until the command is completed. Blipmode is turned off. The only Auto Track Setting checked on is "Display Auto Track tooltip."
Thank you for any help!
Solved by hgasty1001. Go to Solution.
What about dragmode?
Thanks for your response...
Turning "Off" Dragmode works, except then I can't see the line I am drawing or the object as it moves.
I think I had it set to "Auto" in the pdf.
Turning it "On" does what I show with drawing a line, but not with moving objects.
@Anonymous wrote:Please refer to the attached print screens...what setting turns this off in Autocad 2015? Whenever I draw anything or move, copy, etc. it shows this until the command is completed. Blipmode is turned off. The only Auto Track Setting checked on is "Display Auto Track tooltip."
Check the vintage of your video card driver.
1.-Try turning hardware acceleration off, type 3DCONFIG in the command line.
2.-Check if Autocad Service Pack 1 is installed (There is a SP2, but there are some problems reports in this forum)
3.-Check the video driver
Gaston Nunez
Gaston Nunez
