How to import Rhino to Revit with Elemental Intelligence using Autodesk Good Practices or Plugin??
Recently, I have been asked do an estimation of the BIM Bidding , where in client has requirement of converting huge concept data into Revit. I raised the query to Autodesk ATC's without any solution. I request a collaborative MOCK run with the specialist in the forum. In IFC world how Rhino is non-interoperable. I can buy plugin also .Clients still waste time in using non interoperable softwares using non compatible softwares and reduce the time value of the IPD process. Change is not easy. Please do share your expert opinions and help me save a task from the curse of software limitations.
You may have better luck in one of the Revit forums;
http://forums.autodesk.com/t5/revit/ct-p/2003
HTH
HTH
