AutoCAD Forum
FATAL ERROR: Unhandled Access Violation Reading
2 REPLIES 2
613 Views, 2 Replies
i get that error.
FATAL ERROR:  Unhandled Access Violation Reading 0xffffffff Exception at 759baa0fh
twice time today when i draw.
any help?
My PC Information:
I used Autocad 2015 SP2
VGA: Nvidia GT 430 Driver Version: 344.11 (Latest Driver)
OS:Windows 8.1 Enterprise
Memory: 4GB Ram (4.00 GB Usable)
CPU:Intel Core 2 Quad Q8200 @ 2.33GHZ
2 REPLIES 2
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
Q1) Have you tried to open your DWG in RECOVER Mode, maybe PURGE it, ReSave, Quit, ReLoad, Test ...
Q2) THEN - Have you the problem with the DWG on the Network ?
If YES, please try to save it on your Local hard disk, ReLoad from Local hard disk, Test ...
The SP2 for 2015, is not "very good" so you can try to Un-Install it ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
in reply to: braudpat
Thanks Braudpat if the solution work i'll ACCEPT Your Solution As Solution 😄 .
Forma Design Contest
