AutoCAD Forum
What AutoCad is suits for my PC
4 REPLIES 4
756 Views, 4 Replies
I have Acer Laptop Aspire E1 with operating system Windows 7 Ultimate.
Processor : Intel(R) Core (TM) i3-2348M CPU @2,30GHz 2,30GHz
Installed memory (RAM) : 3,00 GB
System type : 32-bit
Display adapter : Intel(R) HD Graphics 3000
What type is suitable for my PC?
Tags (2)
4 REPLIES 4
BeKirra
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/System-r...
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
WarrenGeissler
I would recommend AutoCAD LT based on their system requirements >HERE<
If you want to work in 3D then you need to look at a new computer.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Alfred.NESWADBA
sorry, Intel i3 and Intel HD3000 are not the base for a valid CAD environment, independent of which CAD system you want to use ... as long as you need it in your job.
If it's just to draw a few lines to sketch something you might be able to start AutoCAD, but it's very limited.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
@Processor : Intel(R) Core (TM) i3-2348M CPU @2,30GHz 2,30GHz
Based on your PC/Laptop specs I would suggest that you install AutoCAD LT.
Forma Design Contest
AutoCAD Beta
