We need to know if AutoCAD 2024, will have a new DWG format/version (Newer than DWG 2018 version)
strangby
Message 1 of 72
strangby
Does anyone know if  AutoCAD 2024, will have a new DWG version/format (Newer than DWG 2018 version/format).
Or will it still be the same DWG 2018-version?
When will AutoCAD 2024 be realeased?
For which AutoCAD version will Autodesk change to new DWG- version/format ? (If not on AutoCAD 2024)
Regards
Hans Strängby
BIM/CAD/GIS-samordnare
Building Information Management Stockholm
Replies (71)
Message 21 of 72
pendean
Community Legend
Community Legend
@brian.strandberg wrote:
Big fan of added capability.
Me too 🙂
Message 22 of 72
Ed__Jobe
Totally agree with you, but we have had the ability to add custom objects to the drawing database for some time.  You can look at the objects created by Civil 3d or AutoCAD Mechanical.
That's not the same as what I was talking about. Perhaps my comment about entity types was misleading. Civil 3D has to load special dll's in order for AutoCAD to understand the custom entities. Since the dwg format is a database, there are also tables that contain non-graphical data, such as the Layer table. Updating the dwg format means doing things like adding tables or altering them to add columns (properties). For example, adding the ability for layers to be turned on/off in viewports required adding columns to the Layer table to store those properties. Sometimes they can add new features that are implemented by code in a dll. Other times it requires altering the db.
Ed
How to post your code.
Message 23 of 72
NguyễnHàHuy
I think I should delete the old format .dwg 2000, .dwg 2004, .dwg2007 on that autocad version 2024, the old versions are no longer compatible with windows 10.11 already
Message 24 of 72
Kent1Cooper
When you say "delete the old format .dwg 2000" are you talking about deleting drawing files themselves?  There is no need to do that.  If you are talking about eliminating older versions of AutoCAD software, then I assume it was installed on older computers, so there should be no need to delete it from a newer one.  The software of old versions may not be compatible with newer operating systems, but drawing files from older versions can still be opened in newer versions.
Kent Cooper, AIA
Message 25 of 72
paullimapa
FYI: If you have third party arx apps add-ons installed, these are the most likely candidates that will require new installs when new AutoCAD versions are released even when there is no dwg format change. So hopefully those developers will continue to update their apps by the time the next AutoCAD version is released.
Paul Li
IT Specialist
@The Office
Message 26 of 72
jtm2020hyo
In AutoCAD, almost everything is broken in Windows 11, I hope they fix this for 2024 version.
Message 27 of 72
cadffm
This is offtopic,
but bor the latest update I know about only one 8t two issues, not almost everything.
Sebastian
Message 28 of 72
RobDraw
Are you attempting to use a version that was made for an older OS?
Rob
Message 29 of 72
rgorman
If they DO change formats to something other than 2018 format- only the oldest versions may not be compatible. To avoid this, I have used the TruView to do a bulk conversion to whatever the latest dwg version may be. When the newest TruView is out, just go through all our directories one by one. It's a bit easier with my "Test Station" PC that I use for betas and testing, etc...
That way, I'm not worried that a file created in Rel. 9 will be compatible. It's been updated almost immediately if a new dwg format is standard.
Message 30 of 72
RSomppi
AFAIK, going from an older version is not a problem. Going backwards without conversion can be but not always. It depends on content.
Message 31 of 72
jtm2020hyo
I used 2023 version with updates and appears many bugs.
Message 32 of 72
RSomppi
That's a bit off topic and the wrong version for this thread.
Message 33 of 72
Kent1Cooper
@strangby wrote:
Does anyone know if  AutoCAD 2024, will have a new DWG version/format .... We need to plan for the future....
The thing I keep wondering about this is:  Suppose the answer to that question is "Yes" -- what possible plans can you make before you get the new version and have some notion of what the file format differences are?  That is, of what benefit is it to know ahead of time that there will be a new format, when you probably need to wait until the new version comes out before you can do anything with that information anyway?
Kent Cooper, AIA
Message 34 of 72
strangby
If the answer is "yes" we need to plan for upgrading a GIS system we have developed (with programmed code).  We want to upgrade the system, and actually I would like the answer to be "yes", which means that it will be another argument for upgrading the system. This is one of the main reasons why we would like to know and plan in advance. I imagine there can be many different reasons for many people to know in advance if AutoDesk plan for a new DWG-version.
Message 35 of 72
pendean
Community Legend
Community Legend
@strangby So that begs the question, if this is such a big and important and possibly dire business-planning need, why are you not on the Autodesk BETA testing or even better be part of the Autodesk Developer Network to get all of that inside scoop so you can have all of the urgent dire need to upgrade already planned for?
I suspect you just want an easy answer so you can send someone an email and feel good about it: which is great, always, but not really all that you portrait it to be in reality.
Message 36 of 72
RobDraw
Welp, history tells us that knowing that kind of information comes with an NDA or when the new release comes out.
Anticipation is half the fun of getting there. Enjoy it while you can.
Rob
Message 37 of 72
TOMA62CF
Community Visitor
Community Visitor
It doesn't matter. Once they change DWG 2018, we will cancel our subscription and look for another product.
Message 38 of 72
paullimapa
you may want to start doing trial runs on an alternate product since based on their previous 4 release dates, 2024 could be out as early as March 23:
Paul Li
IT Specialist
@The Office
Message 39 of 72
RobDraw
Yeah, that sounds like a smart move, not.
Rob
Message 40 of 72
JohnPachol
The recent history of DWG versions is:
DWG 2000AC1015AutoCAD 2000, AutoCAD 2000i, AutoCAD 2002
DWG 2004AC1018AutoCAD 2004, AutoCAD 2005, AutoCAD 2006
DWG 2007AC1021AutoCAD 2007, AutoCAD 2008, AutoCAD 2009
DWG 2010AC1024AutoCAD 2010, AutoCAD 2011, AutoCAD 2012
DWG 2013AC1027AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD 2016, AutoCAD 2017
DWG 2018AC1032AutoCAD 2018, AutoCAD 2019, AutoCAD 2020, AutoCAD 2021, AutoCAD 2022, AutoCAD 2023
Based on history, I think we're overdue for a new DWG format.
