We need to know if AutoCAD 2024, will have a new DWG format/version (Newer than DWG 2018 version)
strangby
Message 1 of 72
strangby
Does anyone know if  AutoCAD 2024, will have a new DWG version/format (Newer than DWG 2018 version/format).
Or will it still be the same DWG 2018-version?
When will AutoCAD 2024 be realeased?
For which AutoCAD version will Autodesk change to new DWG- version/format ? (If not on AutoCAD 2024)
Regards
Hans Strängby
BIM/CAD/GIS-samordnare
Building Information Management Stockholm
Replies (71)
Message 2 of 72
jggerth
Anyone who knows is under NDA.  If you want to find out, you'll need to join the Beta program.  And then you'll be under NDA and can't talk about it.  Much like the Dao De Jing
Message 3 of 72
pendean
Community Legend
Community Legend
May I ask why you need to know about that 5-ish months before the software is released?
What is the dire business need?
Message 4 of 72
strangby
We need to plan for the future, and this has to do with other programs and applications that we support and program. We need to plan for the future is the short answer.
Message 5 of 72
RSomppi
Keep an eye out for any What's New for 2024 articles. They sometimes come out a little before the actual release but basically, unless you have insider knowledge as stated above, you will have to wait.
Message 6 of 72
paullimapa
"When will AutoCAD 2024 be realeased?"
This is probably the only question that any of us who are just AutoCAD users here and do not work at Autodesk can tell you.  Since for the past decades Autodesk has issued the annual product update by end of March each year, most likely that will occur again for 2024.
Paul Li
IT Specialist
@The Office
Message 7 of 72
pendean
Community Legend
Community Legend
@strangby so do we all my friend: everyone here is an end user and Autodesk customer like you. You'll not officially hear much of anything until about Feb/March every year. it is only October today.
Or do what the tip above suggested: just don't violate that Autodesk NDA, you'll seriously regret it forever from what I've heard has happened to others.
Message 8 of 72
strangby
Thank you all! I don't want to violate any Autodesk NDA, and I am satisfied with your answers for now. I realize we need to just wait and see then, what dwg-version AutoCAD 2024 will have. We need to plan for the possibility (risk) that there will be a new dwg-version I guess then.
Message 9 of 72
paullimapa
As the popular saying goes: “Hope for the best...plan for the worse”
Paul Li
IT Specialist
@The Office
Message 10 of 72
Ed__Jobe
If you are programming for AutoCAD, you should join Autodesk Developer Network. You can ask the developers questions like that. ADN users are also under an NDA.
Ed
How to post your code.
Message 11 of 72
mkerganou
Hello
Did you get the answer to your question?
I have the same problem of planning ...
Message 12 of 72
cadffm
Sebastian
Message 13 of 72
strangby
No, I don't have any new information.  We need to plan for the possibility (risk) that there will be a new dwg-version. "Hope for the best...plan for the worse" 🙂
Message 14 of 72
mkerganou
Thanks !!!
I asked our dealer ...
If I have any information, I will pass it on to you
Message 15 of 72
DarrenP
They couldn’t tell you anyway it's all under NDA
Join the beta for this information
DarrenP
Message 16 of 72
15 mars 2023
Message 17 of 72
RobDraw
@Anonymous wrote:
15 mars 2023
Does that mean a new format or no?
Rob
Message 18 of 72
brian.strandberg
Anyone in the Beta program can't answer.  It would be nice if someone from Autodesk could give you an answer.
The .dwg file format can handle almost anything right now.  I'm convinced that the 2018 .dwg format upgrade was to 'Help' people transition to named licensing. 😉
If they decide to change the .dwg version and add a 2024 version, I'm sure it will be for similar reasons.  (Economic not Engineering).
(Sorry Autodesk, love you but gotta speak the truth).
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 19 of 72
Ed__Jobe
@brian.strandberg  Just FYI, the only reason for changing the dwg format, which is just a database, is to add/remove functionality, like adding a new entity class type. Strictly determined by programming needs, which is driven by customer needs and business plans. Historically, they wait for a few versions to introduce several features at once, rather than changing it each version.
Ed
Message 20 of 72
brian.strandberg
Totally agree with you, but we have had the ability to add custom objects to the drawing database for some time.  You can look at the objects created by Civil 3d or AutoCAD Mechanical.
Here is a post on adding custom objects:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/AutoC...
I would totally be in favor of a new drawing version if it was faster or more stable.  Big fan of added capability.
