AutoCAD Forum
VIEWPORTS - SELECTING
25 REPLIES 25
Message 2 of 26
1136 Views, 25 Replies
I have a 3D model referenced into a drawing, within that model I have a construction (non print) circle.
I am unable to select any part of that circle other than the centre.
OSNAPS are set correctly.
Any idea?
25 REPLIES 25
Message 21 of 26
in reply to: pendean
Dean, I think you're snapping to the inside of the 3DSOLID cylinder that is very nearly on top of the circle.  Try snapping to the same circle at the bottom where there's a gap in the cylinder.
Message 22 of 26
BTW, what version of AutoCAD is everyone using??
I'm stuck on 2015 for a while.
Dean may be on a newer version that's been fixed.
Message 23 of 26
2015 here...
Message 24 of 26
That could be why we're having the issue and Dean may not be.
Message 25 of 26
Ranjit_Singh2
I do not know about 2018 but on 2017 I get the same behavior as 2015. See Screencast for both, 2015 and 2017 versions. Also looking at co-ordinates in status bar in Post 14 screenshot, it seems like it's reading the modelspace co-ordinates.
Message 26 of 26
in reply to: Ranjit_Singh2
Yep, been that way since R11 (thats R11 not 2011),  dunno what @pendean is snapping to or his version
AutoCAD Inside the Factory
