I have a 3D model referenced into a drawing, within that model I have a construction (non print) circle.
I am unable to select any part of that circle other than the centre.
OSNAPS are set correctly.
Any idea?
Dean, I think you're snapping to the inside of the 3DSOLID cylinder that is very nearly on top of the circle. Try snapping to the same circle at the bottom where there's a gap in the cylinder.
BTW, what version of AutoCAD is everyone using??
I'm stuck on 2015 for a while.
Dean may be on a newer version that's been fixed.
I do not know about 2018 but on 2017 I get the same behavior as 2015. See Screencast for both, 2015 and 2017 versions. Also looking at co-ordinates in status bar in Post 14 screenshot, it seems like it's reading the modelspace co-ordinates.
