AutoCAD Forum
viewport issues
9 REPLIES 9
Message 1 of 10
884 Views, 9 Replies
viewport issues
I insert a viewport on a layout and it's fine. I go to other tabs and when I go back to the tab I just set up the viewport is black. The objects are still there but you can't see the all. I go into the viewport and the background doesn't change. This doesn't happen to all layout tabs just typically my panel tabs.
Please help.
viewport issues
Please help.
9 REPLIES 9
Message 2 of 10
Kent1Cooper
Kent1Cooper
Try REGENALL.  And read about the MAXACTVP System Variable, though I'm not sure that would be the issue -- it's described as a MAXimum number of ACTive ViewPorts "in a layout," but if it's really a maximum total in all layouts, it could have that effect.
Kent Cooper, AIA
Kent Cooper, AIA
Message 3 of 10
Good morning Kent
Regenall did not work I'm sorry to say. I only have one viewport on the tab. I presently have a 27 page (layouts) drawing. The only sheets that are not blacked out are my riser & floor plan pages. When I publish the set it's fine??
Good morning Kent
Message 4 of 10
Patchy
Patchy
Command MAXACTVP and increase the number, see if it helps.
Message 5 of 10
vinodkl
vinodkl
Hi @Anonymous
Seems to be some glitch. Try deleting the old viewport and creating a new one and see if the problem vanishes. Also "PURGE" and "AUDIT" the drawing to remove any errors in the drawing 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi @Anonymous
Message 6 of 10
Valentin-WSP
Valentin-WSP
@Anonymous ,
Consider these solutions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
@Anonymous ,
Emilio Valentin
Message 7 of 10
in reply to: Patchy
Alreadt set to the max of 64
Message 8 of 10
in reply to: vinodkl
That's what I've been doing, comes back.
Message 9 of 10
in reply to: Valentin-WSP
That worked Valentin, thanks alot.
Message 10 of 10
It did it again. The hardware accelerator fixed it.
AutoCAD Inside the Factory
