I insert a viewport on a layout and it's fine. I go to other tabs and when I go back to the tab I just set up the viewport is black. The objects are still there but you can't see the all. I go into the viewport and the background doesn't change. This doesn't happen to all layout tabs just typically my panel tabs.
Please help.
Solved by Valentin-WSP. Go to Solution.
Try REGENALL. And read about the MAXACTVP System Variable, though I'm not sure that would be the issue -- it's described as a MAXimum number of ACTive ViewPorts "in a layout," but if it's really a maximum total in all layouts, it could have that effect.
Good morning Kent
Regenall did not work I'm sorry to say. I only have one viewport on the tab. I presently have a 27 page (layouts) drawing. The only sheets that are not blacked out are my riser & floor plan pages. When I publish the set it's fine??
Hi @Anonymous
Seems to be some glitch. Try deleting the old viewport and creating a new one and see if the problem vanishes. Also "PURGE" and "AUDIT" the drawing to remove any errors in the drawing 🙂
@Anonymous ,
Consider these solutions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
