Difference btw By-layer and default of Lineweights
I see by default option for lineweights also change lineweights  of by-layer. Is by-layer and default same things ?
pendean
Community Legend
Community Legend
DEFAULT is defined on that pop-up you posted, on the right side. It's a one-off setting, you get no variation.
BYLAYER is the lineweight you set in LAYER command, there is a special column for it: you can have different lweight settings for each layer if you wanted it to.
HTH
