Viewbase Problem
Viewbase Problem
Message 1 of 12
Viewbase Problem
Has anyone had this problem yet? I've drawn a model in Autocad 2018, and then when I went to use Viewbase, it gave me this error: Unable to perform the requested action. This drawing was last edited with model documentation in a newer version of AutoCAD.
However, there is no newer version of Autocad.
Replies (11)
Message 2 of 12
imadHabash
I suggest to restart your PC then try it again please.
Imad Habash
Message 3 of 12
Alfred.NESWADBA
Was that drawing created on your system or on another workstation?
And to verify the exact version: start command _ABOUT and compare the release info with that one (my AutoCAD was able to handle _VIEWBASE correctly).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 12
The drawing was created on my work station, I haven't tried opening it on another computer yet.
Message 5 of 12
Message 6 of 12
Alfred.NESWADBA
as you can see your AutoCAD is not up-to-date.
Let Autodesk Desktop App update your AutoCAD and then try it again.
- alfred -
Alfred NESWADBA
Message 7 of 12
This did seem to work, and I am updating AutoCAD as well. As well as cleaning out temporary files, as per a suggestion from Autodesk.
Message 8 of 12
anderson51
I am having the same issue.
My product version says O.49.0.0 AutoCAD 2018
Message 9 of 12
anderson51
What and where is the Autodesk Desktop App to upgrade to the latest version?
Message 10 of 12
Alfred.NESWADBA
What: an application to install Autodesk applications and to search for updates (and install them)
>>>click<<<
- alfred -
Alfred NESWADBA
Message 11 of 12
Is this a vcd player.
Message 12 of 12
even i was facing the same issue while i was doing my drawing as i use VIEWBASE and select the from model space and then selecting object and creating a new layout and after entering
i am getting the same error
Please help me with this issue
sharon
