Change AutoCAD background to black
Message 1 of 8
I have forgotten how to make the background in my drawing space white instead of black. What is the command or where do I go to change the background color to the white, paper color?
Replies (7)
Message 2 of 8
SeeMSixty7
Type OPTIONS at the command prompt. Then click on the Display tab. You will see the Color Options for Various AutoCAD Screen components. Click on PaperSpace or ModelSpace and set their color to black the click OK.
Good luck.
Message 3 of 8
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Type Options and then select the Display tab. On the left middle of the page you will see Colors.
Select the context such as 2D model space and then the Interface element.
John Vellek
Message 4 of 8
rkmcswain
If you change background colors manually, be sure to change the color of the crosshairs to something contrasting.
If you are interested in making a button to quickly toggle background colors between black and white (or whatever colors), then take a look at this. No wasting time opening Options, etc.
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 8
Thanks much! Was easy to do.
Message 6 of 8
Thank you - was easy to do
Message 7 of 8
I have AutoCad 2017 LT. Can I change the background color in paper space? The box under 'options' tab doesn't have all options everyone is referring to.
Thank you
Message 8 of 8
rkmcswain
@Anonymous  - so your AutoCAD LT 2017 does not match this page in the documentation?
http://help.autodesk.com/view/ACDLT/2017/ENU/?guid=GUID-4A6DE078-3D3A-4E23-A12A-93569F32A4A1
