AutoCAD Forum
view from model space autocad not working
8 REPLIES 8
Message 1 of 9
Dan-Rod
481 Views, 8 Replies
Hello there
I'm trying to use the "viewbase" command and it doesn't work for me, I'm trying to bring the views to layout and only a red box appears.
I hope you can help me
8 REPLIES 8
Message 2 of 9
vinodkl
in reply to: Dan-Rod
Hi @Dan-Rod
Try opening a new drawing and copy the model into the new drawing and use the command "VIEWBASE". Let us know if it works now 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 9
Valentin-WSP
@Dan-Rod ,
Check your graphic card is updated and turn on your GRAPHICSCONFIG (type it on the command line).
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 4 of 9
Alfred.NESWADBA
For just this object, or only with this dwg-file and using which version and update of AutoCAD (command _ABOUT shows the exact release information).
If it's file-specific then please show is the dwg-file and the version of AutoCAD you are using.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 5 of 9
Dan-Rod
in reply to: vinodkl
It is on, I restart the computer, it remains the same.
Message 6 of 9
Dan-Rod
in reply to: Valentin-WSP
It is on, deactivate and activate and it remains the same
Message 7 of 9
Dan-Rod
hello, i already did, stay the same
Message 8 of 9
pendean
Share your actual DWG file please.
Message 9 of 9
Valentin-WSP
@Dan-Rod ,
Please provide the information @Alfred.NESWADBA and @pendean requested.
On your AutoCAD command line:
     Type ABOUT and send an image.
     Type GRAPHICSCONFIG and send an image.
     Attach the DWG.
Otherwise, verify and check the suggestions on these links:
Emilio Valentin
Forma Design Contest
