Hello there
I'm trying to use the "viewbase" command and it doesn't work for me, I'm trying to bring the views to layout and only a red box appears.
I hope you can help me
Hi @Dan-Rod
Try opening a new drawing and copy the model into the new drawing and use the command "VIEWBASE". Let us know if it works now 🙂
@Dan-Rod ,
Check your graphic card is updated and turn on your GRAPHICSCONFIG (type it on the command line).
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
For just this object, or only with this dwg-file and using which version and update of AutoCAD (command _ABOUT shows the exact release information).
If it's file-specific then please show is the dwg-file and the version of AutoCAD you are using.
- alfred -
@Dan-Rod ,
Please provide the information @Alfred.NESWADBA and @pendean requested.
On your AutoCAD command line:
Type ABOUT and send an image.
Type GRAPHICSCONFIG and send an image.
Attach the DWG.
Otherwise, verify and check the suggestions on these links:
