I need to change the default value of hpmaxlines.
As soon as I open a new drawing or restart AC Map 2013 the old default value is in use again.
I thought - according to the docs - it is saved in the registry?
Any ideas? Do I do something the wrong way?
Many thanks, Rob
Solved by imadHabash. Go to Solution.
it won't be saved if your new value not between Valid values from 100 to10,000,000.
Hi Imad,
i set hpmaxlines to the max value and it is valid for my current drawing.
So, must be something else that it is not saved permanently,
Rob
