AutoCAD Forum
variable hpmaxlines not saved?
3 REPLIES 3
1059 Views, 3 Replies
I need to change the default value of hpmaxlines.
As soon as I open a new drawing or restart AC Map 2013 the old default value is in use again.
I thought - according to the docs - it is saved in the registry?
Any ideas? Do I do something the wrong way?
Many thanks, Rob
3 REPLIES 3
imadHabash
it won't be saved if your new value not between Valid values from 100 to10,000,000.
Imad Habash
in reply to: imadHabash
Hi Imad,
i set hpmaxlines to the max value and it is valid for my current drawing.
So, must be something else that it is not saved permanently,
Rob
imadHabash
Try this in command line    (setenv "hpmaxlines" "10000000")
Imad Habash
AutoCAD Inside the Factory
