I need to change the default value of hpmaxlines.
As soon as I open a new drawing or restart AC Map 2013 the old default value is in use again.
I thought - according to the docs - it is saved in the registry?
Any ideas? Do I do something the wrong way?
Many thanks, Rob
Solved by imadHabash. Go to Solution.
it won't be saved if your new value not between Valid values from 100 to10,000,000.
Imad Habash
Hi Imad,
i set hpmaxlines to the max value and it is valid for my current drawing.
So, must be something else that it is not saved permanently,
Rob
