AutoCAD Forum
Update 2018.02 available for AutoCAD and AutoCAD LT
0 REPLIES 0
Message 1 of 1
john.vellek
1207 Views, 0 Replies
Update 2018.0.2 is available for AutoCAD and AutoCAD LT and the AutoCAD based vertical products. If you have the 2018 version of those products, you can get it from the Autodesk desktop app or by finding it in your  Autodesk Account.
2018.0.2 Changes
  • Blocks- Right clicking in the Block Edit mode no longer displays an error message in the Command window.
  • Plotting- Certain text styles are no longer upside down when printed to PDF. Self-Intersecting wipeouts in a block will perform as expected when plotted.
  • General- Ability to input values for the Material Editor Palette is restored.
AutoCAD only
  • Digitally signed AutoLISP files can be loaded as expected.
Note: The 2018.0.2 update fixes an issue that would otherwise have caused the product to expire on June 1, 2017 with a pre-release product error message.   Be sure to install this update before that time to avoid product expiration. If the About dialog shows product version number as 0.61.0.0, this update should be applied. Once the update is installed, the version number in the About dialog will show 0.72.0.0
Affected products include:
  • AutoCAD® 2018
  • AutoCAD® LT 2018
  • AutoCAD® Architecture 2018
  • AutoCAD® MEP 2018
  • AutoCAD® Mechanical 2018
  • AutoCAD® Electrical 2018
  • AutoCAD® Map 3D 2018
  • AutoCAD® Civil 3D® 2018
  • AutoCAD® Plant 3D 2018
  • Advance Steel 2018
Please see this AKN article for additional details.
John Vellek
0 REPLIES 0
Technology Administrators
