AutoCAD Forum
AutoCad 2018 Subtract and SurfTrim Issues with Text
3 REPLIES 3
497 Views, 3 Replies
Hi, I'm having a huge issue with some 3d text currently that won't Subtract or Surf trim from an IPhone case I found online that was made with SolidWorks. The IPhone case was originally a SLDPRT file that I then imported into AutoCAD 2018 Student Edition. I currently have made text that says "Innovative Design Studio" as I was hoping to add that to the back of the case. I cannot get either to work though however. It seems depending on where I mouse over the text that it is either a 3d model or surface. The Case under LIST is a 3d Object. I am new to AutoCAD, but it seems to be an easy thing to do however I'm sure that I am making a very easy mistake. Any Help would be appreciated. I have attached my .dwg file.
3 REPLIES 3
Alfred.NESWADBA
you first need to create a 3D-Solid from your letters, then use command _SUBTRACT to cut the letters from the case.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Hey Alfred!
I started out with Mtext and then exploded the letters. From the explode I then extruded them to a .5 heigh so they would go through both ends of the phone case. However the _Subtract command is still not working.
Alfred.NESWADBA
Whenever you extrude non closed polylines you'll get surfaces as result.
If you first close the polylines you've got from the text then you'll get 3D-Solid objects.
HTH, - alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
