All the layers in my xref file are unreconciled in the drawing file. I saw the posts to turn off the notifications. I would rather fix the issue causing the unreconciled layers, and not just turn off the notifications. Yes, it probably is an OCD thing with me.
Solved by s.borello. Go to Solution.
Solved by nmarcelis. Go to Solution.
@Anonymous wrote:
Maybe I need an explanation of what an unreconciled layer actually is....
That's what I want to know, and haven't found any explanation of in Help. What does it mean that a Layer is unreconciled? What does reconciling a Layer do, specifically? What is it for? Are there any drawbacks to not doing it? Etc., etc.
Little explanation of why you get the warning for unreconciled layers:
Unreconciled layers are layers that have been added to the drawing or to attached xrefs since the layer list was last evaluated.
To reconcile a layer in the drawing you have to manually select it and mark it as reconciled.
All layers that have been added to the drawing or its xrefs since the last user-specified action (for example, reloading an xref), are listed.
This will add the layer to the layer baseline and not display it as new anymore in the drawing.
I want to set my AutoCAD so that it does not notify me when there is a new layer added. I have hundreds of detail sheets that I am putting new borders in and having to 'reconcile' 'unreconciled' layers in each sheet is obnoxious at best!
You or someone with access to your setup turned that on for you since that setting is off by default for all of us, and you always could control that for decades now, and still can do so now, as noted in earlier posts above where you are posting, plus there is a page you can get to in HELP in AutoCAD https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Turn-Off-Unreconci...
HTH
