AutoCAD Forum
UNITLESS TO REQUIRED SCALE
3 REPLIES 3
t.miseviciute0320171
895 Views, 3 Replies
Hello, I was given a unitless drawing and I need to figure out what units were used to draw it and how can I transform it to my required units without re-drawing it? Thanks
3 REPLIES 3
Do you think it is imperial or metric.
Would it be possible to upload your drawing?
Chicagolooper
>>"I need to figure out what units were used to draw it"
Measure a part what size you know,
for example in a floor plan:
Switch to MODEL tab
Command: DIST
measure a normal door.
Distance ~1 Units?
Then it is and was drawn in Meter
or 1000?, Then it is Millimeter, and so on.
>>"and how can I transform it to my required units without re-drawing it?"
If you switch from metric to imperial or the other direction,
tell us your units, the current and the unit you want.
Transform:
For example Command SCALE
Sebastian
Please follow these steps:
1. Type DWGUNITS and press Enter.
2. The current drawing unit system is the number in Unit of length <X>
    (1 Inches, 2 Feet, 3 Millimeters, 4 Centimeters, 5 Decimeters, 6 Meters).
3. Enter the desired option (number) to convert to and press Enter.
4. In Linear Display format, select the desired decimal precision and press Enter (i.e. 6 means 1,00000).
5. In Scale objects from other drawings upon insert? type Y and press Enter (optional).
6. In Match INSUINITS to drawing units? type Y and press Enter (optional).
7. In Scale objects in current drawing to reflect change in units type Y and press Enter (mandatory).
8. In Include objects in Paper Space? type Y and press Enter (optional).
Forma Design Contest
AutoCAD Beta
