AutoCAD Forum
Uniform thickness tool?
3 REPLIES 3
520 Views, 3 Replies
I feel as though there is a shortcut for this problem. In this simple 3D model, I need to "cut" out the excess volume from the bottom of my 3D model. The thickness at all walls needs to be 1mm. Is there a simple solution to "vaccum" the extra space out from the bottom? The top shows the compartments.. but the problem is the excess space underneath.
topBottom
topBottom
3 REPLIES 3
JDMather
JDMather
Solidedit>shell
Attach your dwg file here if you can't figure it out.
Solidedit>shell
nestly2
nestly2
It's difficult to tell because there's no indication of overall size, but it seems that removing thiickness from the "bottom" would produce two pieces.  Is this the intent?
JDMather
in reply to: nestly2
JDMather
My interpretation is that all walls are 1mm thick.  (see attached botto/top images)
AutoCAD Inside the Factory
