AutoCAD Forum
Text and Lines Color Problem
5 REPLIES 5
566 Views, 5 Replies
I got a problem with color that I can't fix somehow.
I have few text labels and lines in a drawing that supposed to have black color.
However, color at some point changed to grey.
Color- by layer, transparency- by layer, viewstyle- 2D Wireframe...
The thing is if I double click on a text it turns to black but after regenall it turns to grey again!
Already did restart and everything.
Looks like there is maybe some variable for color control, I don't know
5 REPLIES 5
jggerth
jggerth
if you do a Plot Preview -- does the text/linework display properly - or is it grey?
in reply to: jggerth
Still the same unfortunately.
I copy-pasted text to paper space and it turned to black.
So it's something wrong with model space.
maxim_k
maxim_k
Try to set Model background color to one of ACI colors for example to 9.
Do you see any difference?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Not really. Also interesting thing that it is not only for black/white color.
I can't change to any color at all.
Will try run audit overwise I'll just do explode.
I copied everything to a new drawing and paste it back. Now it works as supposed to do.
Maybe there was some bug.
AutoCAD Inside the Factory
