We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Unable to install custom OEM setup
2305amol
Message 1 of 15
2305amol
Hello Folks,
We are facing a problem while installing custom OEM setup ,When we uninstall custom OEM setup and try to install it again on the same PC showing INSTALL Button "Disable"
Attaching Screen shot for the same may this will help you
Please let me know the proper solution for this as we unable to install it on our PC
Replies (14)
Message 2 of 15
vinodkl
Hi @2305amol
Right-click on the setup and "Run as administrator" and see if that helps and also verify if that package is compatible with the AutoCAD version which you are using 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 15
2305amol
I have tried this still facing same issue
Message 4 of 15
m_latz
Do you have any log file(s) from the %temp% folder ?
It looks like the setup program "thinks" the software is already installed.
regards
Markus
Message 5 of 15
2305amol
I had deleted log file from %temp% folder still facing the same issue..
Message 6 of 15
m_latz
You should not delete the log files. You should zip the log files and upload to the community, that we can take a look.
regards
Markus
Message 7 of 15
pendean
Community Legend
Community Legend
Reach out to your 3rd party vendor for support, see the bottom of the page https://www.rulebuddy.com/
Message 8 of 15
2305amol
Hi @m_latz
This is the only file I have found related to my setup named as "RuleBuddy PlanAssist (CIDCO).log"
Please look into that.
Message 9 of 15
2305amol
Hello Folks,
Message 10 of 15
pendean
Community Legend
Community Legend
Go ask that software vendor for support with their product, here is the link https://www.rulebuddy.com/#contactus
Message 11 of 15
2305amol
Hello Folks,
Message 12 of 15
2305amol
Hi @pendean
can you please give us another solution?? https://www.rulebuddy.com/#contactus is our site not a 3rd party vendor..
thanks in advanced
Message 13 of 15
m_latz
See my picture:
I do not know the "oem setup" tool. But I suppose that the uninstall program did not remove everything from your pc, so the criteria to check if the program is already installed are fulfilled.
I would check if really everything is uninstalled/removed with the "uninstaller".
And if I understood right, you are the vendor of the software ?
regards
Markus
Message 14 of 15
beyoungjr
Maybe you should try CCLEANER or another tool to ensure that all traces are gone after a proper uninstall of the software?
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 15 of 15
pendean
Community Legend
Community Legend
You need to do this to remove your old installation, restart your PC, then try again https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-r...
