Multiple Phase Drawing Sheets within the same file.
I'm looking for the best way to set up a site plan all in one file, that will have sheets A001 Existing Site plan, A002 Demolition Site plan, and A003 Proposed Site plan.
The site plan drawing is a combination of xrefs with info from a site surveyer, civil, and our drawings.
The primary concern is how to show different phases in the same model space, showing some common and some different layers all within the same file.
thanks!
imadHabash
After long experience with such case , I suggest to separate Existing,Demolition and Proposed sites as xrefs . then you can attached them in one file and start turning off layers as you wish . if you don't like this way you can use one site plan BUT with different layers . i mean .. make your Existing elements layers starts with EXIS ( Exis-Walls ) and Demolition with DEMO ( Demo-Walls ) and Proposed with PROP ( Prop-Walls ) .
Imad Habash
