Text Styles with Identical Properties (and Sizes) Showing as Different Sizes
lucasP5W24
Message 1 of 16
lucasP5W24
Curiously, I have two text styles with identical text style properties, both at 3/32" inch tall. When I use these side by side, they are different heights. To make things more mysterious, in the individual mtext properties, they have identical properties here as well.
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
Post your DWG file with that in it, lets see for ourselves.
Message 3 of 16
lucasP5W24
Sure, see attached. Both styles are shown in paperspace on 'layout1'.
Furthermore, in this drop-down there are two 3/32" options... not sure why.
Message 4 of 16
BeKirra
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 5 of 16
clindner
Change your drawing's units (via the UNITS command) to decimal and precision to 8 places. Then check the text heights again. Fractional units can "lie" to you by rounding to the nearest precision.
Please use the Accept as Solution or Kudo buttons when appropriate
Chris Lindner
CAD Technology Consultant @ onebuttoncad.com
AUGI Board of Directors
Message 6 of 16
pendean
Community Legend
Community Legend
See attached, fixed as noted by others: as a general rule, when things look different they totally are for sure.
Message 7 of 16
kenneth.smithV6QLC
The height set in STYLE is different between the two. The automatic rounding of UNITS made it look like they were the same height.
Please be kind, rewind your exploding. Do not explode hatching, dimensions or text. Think of your fellow drafters! 🙂
https://www.youracclaim.com/badges/9aa4a1d5-0d02-4888-be6f-ed8f0653d8ad/public_url
Message 8 of 16
lucasP5W24
Thanks, everyone! I'm wondering how this happened, though. I have the precision set to 1/32 in the file, and created these two text styles "from scratch" at 3/32" tall, so who knows how that happened... strange!
Message 9 of 16
clindner
Caution: the *VARIES* property is not dependable, especially if units are Fractional or Architectural and low precision.
I created two pieces of text; one 0.375 ht and the other 0.400 ht. With Units set to Architectural and 1/16 precision, both display 3/8" height.
I've always been a fan of using the highest precision possible. Doing so provides real-time QC, highlighting any dimensions that are slightly off.
Chris Lindner
Message 10 of 16
pendean
Community Legend
Community Legend
It is dependable if your UNITS precision is set as all the others in this post suggested, and as I reset in the file I posted back for the OP 😉
Message 11 of 16
lucasP5W24
Here's one last question. If I open a complete blank autocad template, set the precision as high as possible, and create Mtext in paperspace using the "standard" text size, there are already four text sizes available to pick from. Why?! See attached.
Thanks, everyone!
Message 12 of 16
Patchy
You open an autocad template .dwt or start a new .dwg?
There is a difference.
Message 13 of 16
lucasP5W24
Open an autocad template .dwt! (see screenshot)
Message 14 of 16
Patchy
Only shows one for me.
Message 15 of 16
clindner
Lol! Yes, lots of things are "dependable" if everything is set up properly to begin with.
Chris Lindner
Message 16 of 16
cad29V4BY
Community Visitor
Community Visitor
Thank you for leading us in the right direction.   Our situation was slightly different.   We found that the "Width Factor" was inconsistent between the two drawings.     "Width Factor" is found under Format / Text Style.
