AutoCAD Forum
Un-able to adjust scale in my view-port windows
5 REPLIES 5
310 Views, 5 Replies
So just as the tile says, I'm unable to adjust the scale in my view-port windows. I'm on my A size paper tab, when I drag my mouse down to the bottom right decimal/scale area its a dull grey and I can't open it to change my scale. I have also tried it from the properties and under the standard scale table it says custom. When I change it to the desired scale it change right back to custom. Thanks in advance for any suggestions.
Jeremiah Williams
5 REPLIES 5
ennujozlagam
it could be your viewport is locked? in the command type MV > lock > select OFF > and pick your Viewport. and see if helps. thanks
imadHabash
This is because you're working on a locked VP , unlock it as shown below and see if any changes ?
Imad Habash
in reply to: imadHabash
Thank you for your reply. I'm not sure if my first reply went through. I sent it from my phone. I didn't think to add this to my origenal post but. The windows are not locked. I've got the student version of 2019 autocad. Thanks again.
edit:
  View port windows are not locked
pendean
Show us: post a video of you in action on your computer in AutoCAD, you can use this free tool to do the recording https://knowledge.autodesk.com/community/screencast
Forma Design Contest
AutoCAD Beta
