So just as the tile says, I'm unable to adjust the scale in my view-port windows. I'm on my A size paper tab, when I drag my mouse down to the bottom right decimal/scale area its a dull grey and I can't open it to change my scale. I have also tried it from the properties and under the standard scale table it says custom. When I change it to the desired scale it change right back to custom. Thanks in advance for any suggestions.
Jeremiah Williams
it could be your viewport is locked? in the command type MV > lock > select OFF > and pick your Viewport. and see if helps. thanks
This is because you're working on a locked VP , unlock it as shown below and see if any changes ?
Imad Habash
Thank you for your reply. I'm not sure if my first reply went through. I sent it from my phone. I didn't think to add this to my origenal post but. The windows are not locked. I've got the student version of 2019 autocad. Thanks again.
