Hey everyone,
I’m having trouble deleting a data link to an external Excel file. I can’t see where it is in thr file, and despite my efforts, it remains in the drawing.
Here’s what I’ve tried:
Additionally, when I use QSELECT, it indicates that there are no objects to select. However, whenever I copy anything from this drawing to another file, the Excel reference is still imported to new file.
Does anyone have any suggestions on how to resolve this issue?
Thanks in advance for your help.
@olszewski_lukasz7PY8Z -Moderation Team has changed the heading for more clarity.
Hey everyone,
Solved by pendean. Go to Solution.
You don't mention this, so just in case.... Can you right-click on it in the Xref manager [your image] and choose Detach?
1. Make a new temporary xlsx and save it in a known location. You will re-path your dead link to this file.
2. type datalink and edit the offending datalink, choose new path and file from step 1
4. link to range a1:b2 (plaseholder) and select ok.. make sure you select ok to close out.
5.type datalink and you should be able to delete the datalink reference.
It worked! Thank you so much. Crazy
It worked. Finally. Thank you so much
