Trim not working for spirals
Message 1 of 16
Hello! I have been drawing spirals in 2D as well as straight lines, as can be seen in the image below, and I needed to trim the lines in between the spirals. In the beginning, everything worked perfectly; however, now I would only allow me to trim straight lines, and not the spirals. Can you please explain me what I have accidently pressed that it stopped working? Many thanks!Снимок экрана 2016-11-25 в 1.14.00.png
Replies (15)
Message 2 of 16
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
For me it is working, can you upload your drawing + let us know which AutoCAD release and service pack you have?
What does the command line tell you during selecting the cutting edges or during selecting the objects to trim?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 16
imadHabash
I suggest to do the follow :
  • use FLATTEN command on your lines.
  • get back and work with trim.
  • try to use EXTRIM command which will trims all objects at the cutting edge specified by a selected polyline, line, circle, arc, ellipse, text, mtext, or attribute definition.after selecting an object and specifying one side of the object, all other objects are trimmed to that object in a single operation.
Good Luck..
Imad Habash
Message 4 of 16
Many thanks for your help! Unfortunately, my AutoCAD 2014 does not know any of those commands
Message 5 of 16
Alfred.NESWADBA
AutoCAD 2014 can run command _TRIM on spiral and lines. just tried it.
So please show your drawing + let us know what AutoCAD tells you when you select cutting edge/object to trim...
Be careful with that command as the polyline created from a spiral is not exactly a spiral anymore. So so if you need high accuracy you should be careful with that command.
- alfred -
Alfred NESWADBA
Message 6 of 16
Hello! Many thanks for your help! My AutoCAD version is of 2014. When I try to trim the line, it says "Select object to trim or shift-select to extend or [fence/crossing/Project/Edge/eRase/Undo]:". It seems like it could not see the helix as a line because it is 3D. Before it worked perfectly for me, as you can see on my project; however, it stopped working for some reason. I am going to attach my file below. I can see that it work for you, so probably I have accidentally pressed something.Many thanks again!
Message 7 of 16
Alfred.NESWADBA
from first post:
If that is changed from 2D to 3D then change it back:
- alfred -
Alfred NESWADBA
Message 8 of 16
imadHabash
Hi.
>> Hello! I have been drawing spirals in 2D as well as straight lines, as can be seen in the image below <<
>> It seems like it could not see the helix as a line because it is 3D. <<
in first post you said that it's 2D spiral and now you said 3D... i guess that you have to be more specific because this will affect the way that we will answer.
Imad Habash
Message 9 of 16
Thanks for your help! What value should I put into the turning height? When I put zero, it did not change anything
Message 10 of 16
When I go into 3D mode, it shows me that a helix is in 3D, but I work in 2D. I thought that maybe this was the reason why it does not work for me in 2D
Message 11 of 16
I have changed the turning height, so now it is in 2D; however, it did not solve my problem with trimming. I have no idea what can be the reason for it not to work
Message 12 of 16
Alfred.NESWADBA
For me it worked after changing that value.
Can you create a screencast video (>>>click<<<) so we can see what exactly is happening with your AutoCAD?
- alfred -
Alfred NESWADBA
Message 13 of 16
Good day, Alfred! Many thanks for helping me resolve this problem. I have attached the video below of what is happening with my AutoCAD - hopefully, it helps!
Message 14 of 16
Message 15 of 16
Alfred.NESWADBA
sorry, missed your video.
I don't see what AutoCAD tells you when you try to select the spiral, the command-line seems to be only one line high and so messages like "invalid object" or something like that (which is now needed to identify the reason) are hidden/invisible. Is there any chance in AutoCAD for Mac to make the command-line higher or to switch to the command-line as separate window (in AutoCAD for Windows it's just needed to press <F2> to get this window).
What happens when you use copy & paste to copy the geometry (spiral and lines) to a new drawing and try _TRIM there again?
- alfred -
Alfred NESWADBA
Message 16 of 16
wispoxy
Add a point with PEDIT where you want it split. Then try trimming again.
