what's wrong here? I can't trim or extend to spline.
Solved by imadHabash. Go to Solution.
HI,
when i try to trim i have a note ( Does not intersect with the cutting edge). and to solve that you have to FLATTEN the spline then every thing going fine.
Imad Habash
how do you flatten the spline? You didn't explain that. I'm trying to trim a spline that is being used to enclose a filled region
FLATSHOT is a command that will do that, and FLATTEN is a related Express Tool. They do things in slightly different ways -- read about them in Help to determine which is more appropriate to your needs.
Or you could convert the spline to polyline (by right clicling on the spline) but that would break it into many smaller fragments.
does not work on LT version which has no flatten command
i have been using break or breakatpoint comand to trim but its a bit annoying
