AutoCAD Forum
trim/extend to spline
10 REPLIES 10
Message 1 of 11
20539 Views, 10 Replies
what's wrong here? I can't trim or extend to spline.
10 REPLIES 10
Message 2 of 11
Patchy
UCS go to World
Plan go to current.
Message 3 of 11
in reply to: Patchy
Thanks, tried that but no change.
Message 4 of 11
Patchy
EDGEMODE is it 1 or 0 ?
Message 5 of 11
in reply to: Patchy
Edgemode is 0. I have tried to change it to 1 and back to 0, no luck.
Message 6 of 11
imadHabash
HI,
when i try to trim i have a note ( Does not intersect with the cutting edge). and to solve that you have to FLATTEN the spline then every thing going fine.
Imad Habash
Message 7 of 11
in reply to: imadHabash
That works - thank you!
Message 8 of 11
how do you flatten the spline? You didn't explain that. I'm trying to trim a spline that is being used to enclose a filled region
Message 9 of 11
Kent1Cooper
FLATSHOT is a command that will do that, and FLATTEN is a related Express Tool.  They do things in slightly different ways -- read about them in Help to determine which is more appropriate to your needs.
Kent Cooper, AIA
Message 10 of 11
in reply to: Kent1Cooper
Or you could convert the spline to polyline (by right clicling on the spline) but that would break it into many smaller fragments.
Message 11 of 11
LSilva64PFC
does not work on LT version which has no flatten command
i have been using break or breakatpoint comand to trim but its a bit annoying
Forma Design Contest
