AutoCAD Forum
Tracer ASCII code to Autocad
11 REPLIES 11
Message 1 of 12
1908 Views, 11 Replies
Hello dear all;
I have a optical frame tracer takubomatic fd80 and ı am getting trace information as ascıı code like below
TRCFMT=1;400;E;R;F
R=2700;2709;2719;2728;2739;2749;2759;2770;2781;2792;2803;2815;2826;2838;2851
R=2863;2877;2889;2901;2913;2926;2938;2950;2962;2973;2985;2997;3009;3021;3033 ........
The R means radius. ı would like to get this drawing in auto cad but ı dont know how ı can be import this ascı code to auto cad. I search lot but ı did not find anything can  some one help me about it please.I just add my tracer output file. You can see fulll.
Labels (3)
11 REPLIES 11
Message 2 of 12
Alfred.NESWADBA
>> The R means radius
Sorry, this is not enough information, I even don't know what these 3 ascii files should show.
"R" is radius does not mean anything here as the big amount of numbers is not described, what does the other numbers mean?
I was also not able to find any documentation about this device and it's output.
And maybe important too: what does this data have to do with CAD?
A bit more information is necessary to get suggestions or solutions in the replies.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 12
in reply to: Alfred.NESWADBA
Dear Alfred Thank you for trying to help me.
I am trying to expalin but ı now it is not clear so ı found our tracer data comunication standarts file under this link https://docplayer.net/52539558-Data-communication-standard-version-3-10.html
under this link page 18 and page 19 is explaning . I am trying to get traced data to autocad.
Message 4 of 12
Alfred.NESWADBA
thank you for the link with the description of the ASCII-data.
First guess to this: if this manufacturer does not have a file-format that can be imported in AutoCAD I would not know any way to get these values imported in AutoCAD, at least not OOTB, maybe an app exists (ask the reseller or manufacturer of this device).
Second: at least for me it is too specific to a branch to understand wordings like "TRCFMT record" or "ZFMT record" (and much more inside this document) to be able (and to have time enough) to think about the steps which might help to import the data. Therefor sorry, I'm out.
- alfred -
Alfred NESWADBA
Message 5 of 12
Dear Alfred;
Thank you so much to you for your effort. At least you try to help me ...
Message 6 of 12
Hello Dear All;
I found solution and ı would like to share here to help someone maybe need in the future. The tracer output .txt file was like thi
TRCFMT=1;400;E;R;F
R=2700;2710;2721;2732;2743;2754;2764;2775;2785;2796;2808;2820;2832;2843;2854
R=2865;2875;2885;2894;2904;2913;2922;2931;2939;2948;2956;2963;2970;2975;2980
R=2984;2987;2988;2989;2988;2986;2982;2978;2972;2966;2958;2950;2941;2930;2919
and ı relise the number 2700;2710..... means how far from the center and there is a 400 diffrent mesurment there and ı make one script file as like below
multiple line
0,00 @Anonymous.00<0.90
0,00 @Anonymous.10<1.80
0,00 @Anonymous.21<2.70
0,00 @Anonymous.32<3.60
0,00 @Anonymous.43<4.50
0,00 @Anonymous.54<5.40
0,00 @Anonymous.64<6.30..................
0,00 means x and y cordinate is orgin  one space for command and @Anonymous.64 is how long will be my line and <6.30 is degree . ı did this for 360 degre .
I try to explain soryy my bad english.
You have a great day for everyone.
Message 7 of 12
Message 8 of 12
TerryDotson
What do you know about the header section (especially the HBOX, VBOX fields)?
REQ=FIL
CIRC=172.52;172.52
CSIZ=00.00;00.00
HBOX=55.73;55.73
VBOX=49.06;49.06
DBL=0,00
FTYP=2
ETYP=1
See the attached drawing, the space between centers is still up in the air.
Message 9 of 12
in reply to: TerryDotson
Hello Dear Terry;
I dont know what are they but ı am just guessing they are frame outside dimention. I am just guessing maybe ı am wrong.
If you find diffrent thing please let me know. I dont want to make any  mistake
Message 10 of 12
TerryDotson
I guess I was looking so hard for a value defining the DBC (distance between centers) that I overlooked the obvious, you are right about HBOX/VBOX.  I suppose the "DBC" varies with the bridge used and can vary by person.
In looking around, I see where some people want to use CAD to design frame shapes and create .OMA files directly from CAD, which is possible (with custom code) also.
Message 11 of 12
Teryy;
our tracer doesnt mesure center to center bc this tracer made for just get a lens dimention. The tracer neadle (read point) When read one side dimention after it is going back inside of the machine and slide all the way other side and comeing out for read other side but it is not mesuring bride.
Message 12 of 12
gusgarment
Hello my friend, how did you convert the OMA file into CAD? I am also looking for a way to do this, thanks in advance.
Forma Design Contest
