AutoCAD Forum
Tool Palette samples
2 REPLIES 2
jjmill1
80 Views, 2 Replies
How do I get actual blocks into my tool palette bars, instead of the samples?
I am using AutoCAD 2025, with windows 11.
I am using AutoCAD Symbols 200 now, from my design center.
2 REPLIES 2
cadffm
in reply to: jjmill1
>>"Tool Palette samples"
ToolPalettes, CTRL+3 ? Okay..
>>"How do I get actual blocks into my tool palette bars, instead of the samples?"
The answer is: DRAG&DROP Blockreferences or Files, which are designed for using "as Block" definition.
>>"I am using AutoCAD Symbols 200 now, from my design center."
If you have drawing files with blocks, it is possible to create ToolPalette Tools via DesignCenter: DC ->on Block section of a file -> on the right: RightClick -> Create ToolPalettes
NOTE: ToolPalettes DO NOT contain blocks, you just create a button with the information to insert a block(or file) FROM....<c:\just a linik to your source file>
so it is important to think twice from where you add the blocks/files - these files are not part of a "Export settings" or  "migration from previous version" action.
Sebastian
pendean
@jjmill1 wrote:
...I am using AutoCAD Symbols 200 now, from my design center.
I take it you never tried this before, try it now:
In ADC ('design center'), right-click on each sub-folder of your old symbols library and choose
CREATE TOOL PALETTE OF BLOCKS
Done. you now have a TP of that stack of blocks, name of the subfolder is the name of the TP.
Repeat for each subfolder of blocks from your old symbols library.
Forma Design Contest
AutoCAD Beta
