Hi!
I'm new to autocad 2018 and I'm having trouble finding the hole tool. I need to create a threaded hole for an M4 screw: is there a tool to make standardized (threaded) holes? If yes, where can I find it, and if no, what alternative can I use?
Thanks for your help.
@Anonymous
john.vellek has edited your subject line for clarity: Threaded hole (M4 dimensions)
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
There is no built -in feature that will draw real threads in AutoCAD. You can certainly create a helix and then sweep the thread profile long the helix as a path but this requires some math calculations on your side in order to determine the pitch of the thread.
Inventor is likely better suited to this task and there is a rather slick utility in the Autodesk App Store called CoolOrange that might be worth investigation.
In AutoCAD, you would just create a cylinder and SUBTRACT that from the solid body you are working with. Then dimension the hole appropriately. In Inventor, it does not model the actual threads but it is a Hole object with properties that can be used to automate dimensioning. It uses a bitmap image to show the threads. You can also model actual threads similar to what John mentioned if you need to have actual thread geometry.
McMaster-Carr has 3D models (IGES) of every fastener and most mechanical products they sell.
Select the size capscrew you need, click on the part number and you will see a selection of 2D and 3D formats to download.
Use the capscrew in a subtract operation and you have a threaded hole.
